I want to join the face of the bottom cylinder to the two points at a smooth curved gradient as seen in the screenshot (bad drawing) - center line. Also what's the best way to divide the lower chamber of the cylinder in in 2 halves apart from actually drawing a 2mm rectangle and extruding?
I've tried connecting the points by using an offset plane but its not working at the center and I think dividing in two and then adding a slope is not the right way? But idk.
Thanks and appreciation
