creating coping templates for rolled section of 8" pipe
davidK4NBJ
davidK4NBJ
I need to create a series of printable templates to mark out and cut copes several pieces of 8" pipe that are rolled to different, quite large, radii. Will be very grateful for any advice or wisdom.
akash.nawghare
Hi @davidK4NBJ
Could you please share the file i will try to create a solution for you. Thanks
davidK4NBJ
sure thing. thank you
Warmingup1953
I think we are going to need the Fusion file with the source Sketches to have a meaningful crack at a solution.
Paper, like a Fusion Sheetmetal body, can't unfold compound curvatures.
Have you used this method before?
Would 3D printing be an option?
Warmingup1953
My rough go:
davidK4NBJ
Thank you all for the input. We are currently working on 3d printing the templates and it seems to be working.
obulesub
Hi @davidK4NBJ ,
Glad to hear that the 3D printing approach seems to be working for your templates.
If the guidance from Warmingup1953 helped move you toward a solution, please consider marking the reply as the Accepted Solution. This helps other community members find useful answers more quickly.
Thanks!
Obulesu | Community Manager
