How to inset a single component from a mulit-component part into a new design?
chris.shieldsR5AE8
chris.shieldsR5AE8
I have a design that is 3 dodecahedron dice in a box. Each die, and the box, is a component.
I want to start a new design, using the same die. So I would like to insert just ONE of the components (read: a single die) into a new design and start working on that one. These should all be the same size dice, so if I change the parent, I want those changes to precipitate through to this new design.
Is it possible? I keep finding links and tutorials on how to insert a whole part (all of its components and sketches, etc) into a new design, but that's not what I'm trying to do here. In hindsight, I'd redesign this as a single parent die, and insert that into a new part, make new components, then my box, etc, etc... but... you know, time and all that.
Thank you very much
davebYYPCU
Check out the Derive Function,
means the current file will always be the Master, (gets around the hindsight)
Might help....
chris.shieldsR5AE8
I have another project that I have to jump over to for a while, but I will certainly check this out. Thanks for the tip
