How to import Solidworks model with features rather than as a body.
Message 1 of 15
I am trying to import some Solidworks models into Fusion 360 and modify them. However, the parts load as bodies with no features that I can modify. I have been unable to do anything with these models but look at them. I am unable to select or modify anything. I do not have the time or inclination to reconstruct these models in Fusion. If I can not import and modify, then I'll have to go back to Solidworks. So far this software has been let down, very disappointed.
Replies (14)
Message 2 of 15
ChristophUnbescheidt
Hello!
first of all there is an english Fusion360 Forum here:
https://forums.autodesk.com/t5/fusion-360/ct-p/1234
Second did you try to rightclick on your model and say create Fusion Design (in your File Browser)
Hope that helps you 😉
Industrial Designer
c.unbescheidt@gmail.com
Message 3 of 15
Roman_Vesely
Hi Vonissar,
thank you for the trying the Fusion 360, welcome !
Now back to your question. Unfortunately Fusion 360 & Solidworks aren't "synchronized" as you expected. Models from the Solidworks are imported after the Upload as bodies.
BUT in the Fusion is a tool called "Find Features"
Find Features
It's a feature recognition tool so all recognized Features:
aren't features from the original model but you can edit them or Dissolve them if you aren't satisfied:
So no you could have your model and recognized Features.
Now you can continue in Direct modeling mode or enable "Capture Design History" modeling mode when you can making parametric models.
I hope this will help you.
 Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
Message 4 of 15
michallach81
Can you tell me how Fusion could import features from other cad software??
 @Anonymous are you aware, that Sweep or Loft in Solidworks have different settings, and uses different algorithm to create surfaces/bodys? Even more, Solidworks uses Parasolid geometry kernel, where Fusion uses ASM kernel (kernel, build on ACIS kernel). What's the different, take a look at fillets/blends made on same geometry with 4 different kernels used:Blends.JPG
To fulfill your request Autodesk should copy whole Solidworks code, and anything new should add on top of that...then let me ask, are serious???
Telling us that you're disappointed, you're showing how ignorant you are, and not having any respect to others hard work is rude and impertinent.
More modesty, please.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 5 of 15
Roman_Vesely
Hi michallach81,
 well. Right now Fusion doesn't have a support for import features - for any CAD files.
For Inventor models we have in place an "automatic" feature recognition for all imported files. But some features aren't 100% covered (like threads).
Regards
 Roman
Roman Vesely
Message 6 of 15
michallach81
Nevertheless, certain tools are different in various CADs, we can have feature recognition if features will act the same. I've made simple compare between loft in Onshape and Fusion. Those are same surfaces, same "smooth/match curvature" (G2) options enabled, but still different resault. Surfaces in the middle don't match... so what would happend if on those Lofts we would relay other features down the stream?
Michał Lach
Designer
co-author
Message 7 of 15
Roman_Vesely
Hi michallach81,
The result for "feature recognition" vs "Loft feature" is a different ... so it seems to be an issue probably. Thank you for reporting this.
Could you send me (to my Autodesk email: roman dot vesely at autodesk dot com or attach to the post) this design document, please ? I will send it to our modeling team for the future investigation.
Thank you
 Roman
Roman Vesely
Message 8 of 15
michallach81
Hi Roman, you didn't understand me. I'm not arguing about Feature Find in Fusion360, I was trying to explain why it's a stupid idea, to demand features to be imported from other CADs.
Michał Lach
Designer
co-author
Message 9 of 15
Roman_Vesely
I see.
 you are right. It would make sence if these CAD systems will have the same modeling kernel - which is unfortunately not our case.
Regards
 Roman
Roman Vesely
Message 10 of 15
jeff_strater
@michallach81is correct - it is a huge technical challenge to try to do feature-level translation between parametric CAD systems.  And, it's not just the modeling kernel involved (althought is, indeed a big factor).  It's also the applications' data model and behavior.  All it takes for failure is one missing flag on one feature type.  If that feature happens to be in the first few features of your design, then the rest of the design is suspect.
To my knowledge, this has never been successfully done before in the industry.  Autodesk attempted it (Mechanical Desktop to Inventor), and that was same kernel, and even the same people who were working on both projects.  We got close, but nowhere near 100% success.
This also is why direct modeling systems have become popular in some industries.  You can edit an imported design without having the feature recipe.  This is why we've kept Fusion Direct Modeling as a choice for design type, and also why imported designs default to direct.
Jeff
Jeff Strater
Engineering Director
Message 11 of 15
Message 12 of 15
michallach81
About post above I'didn't notice that I was logged in to my friend account, so I removed my anwser.
What I would like to say is, that I don't like when someone have enough nerve to say about his disappointment, and did not put any effort to get know some cad basics... pitty.
Just to make it clear, all I'm saying is just a rant, but if someone feels entitled to show his disrespect, then I'm equally entitled to express my opinion on that.
Michał Lach
Designer
co-author
Message 13 of 15
Hi @Roman_Vesely,
As you pointed out, the "Find Features" tool only works when the design history is disabled. For me, after it finds some features, if I then enable design history, all of those are lost - the feature tree on the left just has the imported body and the timeline only has one item: the base feature from the import. Were you able to preserve editability of the recognized features after enabling the design history?
Thanks a lot,
Jeff
Message 14 of 15
Hi @roman_vesely,
Thanks a lot,
Jeff
Message 15 of 15
Roman_Vesely
Hi Jeff,
 once you have enabled "Capture Design History" you have created "Base Feature" in the Timeline. If you want to edit "features" which identified command "Find Features" before, you need to select "Base Feature" in the Timeline, do RMC and select Edit (or just do a double-click on it) :
All "Features" are available for editing:
That's all 🙂
Regards
 Roman
Roman Vesely
