How to get overall dimensions of my part?
Hello everyone,
How can I get the overall dimensions of my part? I'm making a blood vessel network and need to know what the overall length/width/height my model is. Any suggestions?
Best,
John
If you make a setup in CAM and right click it, goto edit it will pop p a window. Click the stock tab and the bottom pane will show the dimensions of a rectangle that contains your model.
I'm very new to Fusion 360, what do you mean by make a set up in CAM? What should I be right clicking once I do that?
Thank you for your speedy response!
jasonhomrighaus
if you right click on your model in the browser and then select "Properties" you will find info on the weight and the bounding box dimensions of the model.
My bounding box says 0mmx0mmx0mm. It should be 1.15 mm long, .3 mm tall, and .15 in diameter. I need it that small for my specific project.
That would be faster. Since I am in CAD space mostly I didn't see that one.
Thank you very much!!
