How to generate drawings for sheet metal model with many bodies?
ashes.man
Message 1 of 8
ashes.man
I would like to generate a set of drawings suitable for sending for laser cutting from a sheet metal model that has multiple bodies, each of which is a sheet metal part.
I can see how to turn each part one by one into a flattened panel and create a drawing, but is there a more automated way to do this to get all the flattened part drawings?
Are the F360 drawings suitable for sending to a laser cutter or is there a way to export a dxf of just the cutting profile?
I am open to better workflow suggestions
Model attached
Edit:  I am using the free F360, it looks like dxf export is not available for me?
Replies (7)
Message 2 of 8
mango.freund
Message 3 of 8
HughesTooling
I think you can export a DXF from within the flat pattern workspace so you could make 2d drawings and save as PDF and also supply a DXF of each part.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 8
ashes.man
Thanks, I just tried and you are correct. What I just learnt was that you can only have one flat pattern per component. I guess I need to separate all my bodies into components so I can make a flat pattern for each one.
Message 5 of 8
HughesTooling
Yes you need a component for each body.
Mark
Mark Hughes
Message 6 of 8
ashes.man
It turns out you cant convert a sheet metal body to a component. So I guess that is tomorrows job, restructure the model into components...
Message 7 of 8
jhackney1972
Take a look at this blog article and video, it will saved you a lot of time allowing you to convert sheet metal bodies into sheet metal components.
John Hackney, Retired
Message 8 of 8
ashes.man
Thankyou for your workaround.  Initially I thought I would still go back and make new components so the sketches would be with the components, but then I realised you cannot transfer things from the feature tree between components so would have mean redrawing sketches and starting from scratch.
I have converted all my bodies into sheet metal components by your method.
