How to freeze the orbit center
hugues1965
Message 1 of 8
hugues1965
I work with my 3D mouse in left hand and regular mouse in right hand.
I would like the orbit center to stay where I place it. But for some reasons, as I move the part and perform different actions, the orbit center often moves away from that location. I then have to interrupt my workflow and replace the orbit center. It's really quite annoying, it happens often, every few minutes or so.
Is there a way to freeze that orbit center, whatever actions I perform ?
Replies (7)
Message 2 of 8
rajeshpolamuri
Hi @hugues1965
Could you try by grounding the component?
Hi everyone, I am Rajesh. I am graduate of Mechanical Engineering in India. I am passionate on creative works like CAD, Art's, Edits, Designing, Etc..... I am also an Autodesk Student Ambassador. I was always shows my interests on the works. Which makes effective and updating every time, With the modern world.
Message 3 of 8
hugues1965
Hey Rajesh,
I thought for a minute that you nailed it, but no, it does not stay, even if I set the orbit center on a grounded object.
But thanks,
Message 4 of 8
rajeshpolamuri
🤔🤔🤔 okay
Can you share the file ?
I will take a look onec.
Message 5 of 8
hugues1965
Actually I have the problem for all my projects,
so I created a simple project with a red and green block,
To reproduce:
- I right click in the design windows and select "Set Orbit Center"
- I then select one of the corner of the red block
- Then for example I move the green block a bit
- Right away after the move is done, the orbit center moves to in between the 2 blocks.
- Same happens if I simply click on the little house icon top right.
I use a 3D mouse from 3DConnexion, don't know if it is related to that.
Message 6 of 8
rajeshpolamuri
Hi @hugues1965
The orbit was changing every time as per the view, for every zoom in and zoom out view. it will not be fixed. It was automatically placed as per the view.
Message 7 of 8
hugues1965
exactly, and that's the behavior i don't like. we should have an option to freeze the orbit center.
I will open a new feature request I guess.
thanks for your input.
Message 8 of 8
rajeshpolamuri
The axial length was based on the view. Let's wait for the new roadmap update by making an considering this point this time 🙂. Let's make an idea for fusion team for this.
