How to fill in mesh to make solid object?
joshpigford
joshpigford
I've created a mesh surface that I'd now like to fill in to make a full, solid object. Use case here is that I'm creating this object to ultimately be cut out of wood on my CNC machine, but the issue here is I just have the surface instead of the filled in area.
I'm ultimately wanting it to be level/flat on the underside.
SaeedHamza
You need to patch it from the bottom and then stitch it
I can take a look if you could share the mesh
Regards
Saeed Hamza
joshpigford
Here's the file I'm working with.
SaeedHamza
Here is a screencast
Regards
Saeed Hamza
joshpigford
Saeed, this was so fantastically helpful. Thank you so much!
