- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello guys,
I started again to play with Fusion, I was thinking while I learn to model it's a good ideea to start modelling something that will be usefull for me, so I started to model my workshop space, right now I try to think of the best way to store the sheet of policarbonate, and fiberglass that remain after I mill from a larger sheet, every few days I also need to mill smaller parts and it's nice to have them separated by thickness, when I'm looking for a part to look exactly in that compartment.
I try to model the metal part bello, I want to cut it in half, and use each half for one shelf. So I made a 5mm circle and I tried to find a way to duplicate it 22 times, I could only find Rectangular pattern command, and made 22 copies of that circles. But now I can't extrude all at once, I can make the first one, but can't select the other. Also If I extruded the first one, others didn't extrude.
So what is the proper method to make multiple copies of one thing, spaced by let's say , 50mm ??
