How to extend a mesh?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have an STL of a handle and need to make it longer. I imported the mesh with the right units and then split it along the middle and moved each half out the desired length. However I can't figure out if there's a way to now fill the gap in between. I tried Erase and Fill but it had no effect when either selecting the faces or the two meshes so I guess that's not it. Combine is not it either. Is the only way to do this to convert it into a body (either the original single mesh or the two mesh halves)?
