Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
How to exclude specific timeline features (e.g., an extruded cut) from a projection in the drawing view?
3 REPLIES 3
ah.harvey
289 Views, 3 Replies
I'm very new to Fusion 360, apologies if I've overlooked something obvious.
I'm designing an item that consists of three wooden board components that are sandwiched together. Once assembled, the middle (sandwich filling) component will have a hole drilled in from the edge, the diameter of which is wider than than the width of the wood.
I've set all this up in the design view, including extruding the drilled hole after the three pieces are assembled. I'm now trying to prepare some cutting plans in the drawing view.
Because the drilled hole is wider than than the width of the centre component, when I add a plan view of this component to the drawing it is split into two pieces. The hole will be drilled after assembly, and so it is not very useful (and a little confusing) to include this feature in the cutting plan.
What is the best way to exclude specific timeline features from a projection in the drawing view.
I'm attaching some images which hopefully will explain my issue more clearly.
Tags (2)
Labels (1)
3 REPLIES 3
https://youtu.be/o5NsPOcXLho?t=177
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
ah.harvey
in reply to: ah.harvey
perfect, this works! thank you @rushabhthakkar_910
I am glad it helped you.. 😉
Thanks and Regards,
Rushabh Thakkar.
Technology Administrators
