Have some components that were imported into F360 from an assembly STEP file.
Have tried 1000 manipulations to export as STL four different bodies so as to be able to align them for 3d printing using Simplify3d. However each body seems to have a similar "origin" centred on itself such that they superpose in the slicer rather than aligning to their original relative positions as in the Fusion360 file. (That is, after running the appropriate command in Simplify3d.)
Have read lots of posts in the forum about this sort of thing but, quite frankly, still don't understand.
What steps should one take to ensure that various Bodies (I assume one should export Bodies and not Components as STL for good relative positioning?) retain references to some common origin such that they can be aligned in a Slicer program for 3d printing?
