How to enable the new "constraint components" feature 2603.0.86?
tookemtoni
Message 1 of 9
tookemtoni
I updated to 2603.0.86 and I don't see the new icon.  See screen capture.
(view in My Videos)
Replies (8)
Message 2 of 9
tookemtoni
Looks like you need to enable the new assembly UI tab in preferences to get to this new feature.
FYI This preference checkbox did not show up after the update. It showed up after a second Fusion restart.  No biggie but it was a bit confusing, I hope this helps others....
Message 3 of 9
Richard.stubley
I'm looking into this, I'll get back to you ASAP.
Not that it helps you but I see it in the same build number, it may have been a permissions thing.
Richard Stubley
Product Manager - Fusion Mechanical Design
Message 4 of 9
Richard.stubley
Hi @tookemtoni, can you search for it?
Richard Stubley
Message 5 of 9
Richard.stubley
Hmm, it should show up without the new Assembly Tab UI Feature flag.
Could you try turning that feature flag off and see if it remains.
I'd love to hop on a zoom call to take a look if you are available?
Richard Stubley
Message 6 of 9
mayank.malukani
@tookemtoni Can you please try clearing Fusion's cache data + restart and see if the command appears.
Message 7 of 9
tookemtoni
Hi @mayank.malukani and @Richard.stubley,
It's working now but maybe it should be made clear that users need to turn on the new UI assembly to see the new constraint components feature.
Message 8 of 9
a.laasW8M6T
You Shouldn't need to turn on Assembly tab to use constraints
I can use it fine with it off
Andrew Laas
Senior Machinist, Scott Automation
Message 9 of 9
mayank.malukani
Thank you @a.laasW8M6T , yes we do not need the 'Assembly Tab UI' on to see 'Constrain Components' command. @tookemtoni Looks like a temporary cache issue at your end. Glad to hear its resolved now.
