How to edit a project's description?
colin.mcdonald
Message 1 of 13
colin.mcdonald
Hello all:
... there's some old questions on this from back in 2015 and 2016, which I've tried, but I'm still looking at all these "New Project" descriptions in the Fusion Data Panel.
  Q: How do edit the project descriptions?
Thanks again, C
Replies (12)
Message 2 of 13
daniel_lyall
left click on it then long left click again on the name you wont to change it works the same for sketch, body, component and plane.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 13
SaeedHamza
@colin.mcdonald
What do you mean by discerption?
Saeed Hamza
Message 4 of 13
daniel_lyall
@SaeedHamza Its name as a description of what it is like if it was a bookshelf and the body was a shelf you would call the body a shelf this describes what it is in one word.
Daniel Lyall
The Big Boss
Mach3 User
Message 5 of 13
colin.mcdonald
Hi Daniel:
... thanks for the reply -- but, nope.
(Where exactly are you "long clicking"?)
Cheers, C
Message 6 of 13
colin.mcdonald
... in the data panel, below the project name -- see the attached snap, "New Project" = description.
C
Message 7 of 13
SaeedHamza
@colin.mcdonald
Go and click on your name in the Data Panel to open A360, then open the project you want to change its discerption
You will see something like the attached picture appearing on the right of the screen that contains information about the project
Double-click the project name and change it
Regards
Saeed Hamza
Message 8 of 13
colin.mcdonald
Hi Saeed:
... Thanks for the reply.
  Unfortunately, you're changing the project name, not the description.
Cheers, C
Message 9 of 13
daniel_lyall
do you wont a project's name changed
do you wont parts of a model's elements name changed like the sketch, body and work plane.
Do you wont to know how to set the model's properties by what its made from
Do you wont to know how to set the model's properties as in the pick below what you get to by right clicking on a component or the top node/top of tree and selecting properties.
Daniel Lyall
The Big Boss
Mach3 User
Message 10 of 13
SaeedHamza
@daniel_lyall
This is what he's talking about
Which I believe can't be done currently
Saeed Hamza
Message 11 of 13
daniel_lyall
More than likely
Daniel Lyall
The Big Boss
Mach3 User
Message 12 of 13
colin.mcdonald
Hello Daniel and Saeed:
... Yes, I am trying to change the *project* description -- as shown in the data panel ... (not the other things listed above, which are part of a design itself).
C
Message 13 of 13
daniel_lyall
As far as I know you cant change a master project file description in the data panel yet, only when you first do it.
Daniel Lyall
The Big Boss
Mach3 User
