I'm trying to edit a specific line in my sketch but every time I do, the whole sketch scales to match the changes. I included a gif so you could see what I mean. I should mention that I'm very new to Fusion (transitioning from 123D & Tinkercad).
Solved by TheCADWhisperer. Go to Solution.
I'm not quite sure what "the whole sketch scales to match the changes" means. I don't see anything being scaled. What I see in that GIF is mostly expected behavior, other than it looks as if you are missing a horizontal constraint on the horizontal line to the right of the point being dragged, so that line stops being horizontal.
What changes do expect to happen when you drag this point?
Jeff
@jeff_strater I only want that line to change it's length. I should mention that I'm very new to Fusion (transitioning from 123D & Tinkercad). I have a feeling it has something to do with my constraints, I realized I had them un-checked in the sketch palette.
@TheCADWhisperer Here's my file
I recommend that a beginner sketch one line, arc or circle and dimension it immediately.
Then sketch next line, arc or circle and dimension immediately.
If at any step the geometry does not turn black (full defined) stop and ask questions before continuing.
You have two vertical lines overtop of each other at the origin.
The dimension does not go to the origin (zoom in close).
