How to drag component to another component
Pavel6T3X9
Pavel6T3X9
Hello! I met a problem, from some point a cannot drag components in another components in assembly
For example:  I have a lot of screws, nuts, bolts or other same things in assembly. I want to put them all in one  sub-combonent like a "folder" for more easyler navigation in browser.  At start of work I did it normally, but after some time this function is no longer avaliable. And if i drag one or group of components nothing happens
This is how it looks in new assembly. Blue line appears and i can drag comp 3:1  into comp 2:1
And in my designt this is not working.  Browser do not react on this dragging
robert.filiks
Hi @Pavel6T3X9
Thanks for posting!
There is an item after the timeline marker (grayed one). The timeline is preventing the restructure of the body due to timeline errors or references that exist in the design. It is not possible to move the body and maintain a parametric history for the design.
To move component with the history marker not rolled to the end, use one of the following workarounds:
  • Copy Body and use the Paste New command from the right click menu in the Browser.
  • Disable the timeline.
Robert Filiks
Software QA Engineer
My screencasts | Advanced Manufacturing | Tips and Best Practices
Pavel6T3X9
Wow, it helps. Thank you much!
g-andresen
try this
1. move timeline marker to end
2. compute all (ctrl+B)
3. drag & drop components
günther
Note the numerous error messages!
Pavel6T3X9
Thanks you, it works now.
In future i will try to avoid or correct any errors
light24bulbs
That solved it! That UX definitely needs work, as it isn't discoverable that the timeline history is preventing moving components around.
nunya_business
This took me way to long to find - Thanks!
