How to do a Fillet like this ?
jda70az
Message 1 of 19
jda70az
Attached is an image with green lines I did in Photoshop that shows what
kind of Fillet I need but I don't know how to do.
Anyone here know how or got any ideas?
I'm stumped.
Replies (18)
Message 2 of 19
laughingcreek
typically you would do a variable radius fillet, but your geometry looks a bit funky.  if you can get it back to a clean edge then it shouldn't be hard, if not might take a bit more effort.  can you attach your model (preferably an original fusion file with the history) you can export the model as a .f3d and attach to a post
Message 3 of 19
davebYYPCU
If I interpret the pic correctly, not fillet.
The smaller left end is a groove, use sweep, or Extrude.
the opening end is a loft, Merges two different profiles.
Might help....
Message 4 of 19
fusiondesigner
Not clear exactly from your picture, but did you try the "Variable Radius" option in the Fillet dialog?
Message 5 of 19
fusiondesigner
Adding one more picture to show multiple control points.
Message 6 of 19
jda70az
Don't let the black lines fool you. I did 2 fillets on two edges of the variable radius type
and that is how it turned out.
Anyways here is the file.
Message 7 of 19
jda70az
The fillet is going in the wrong direction. The start and end are reversed.
I need it to go the other way. From the sharp edge on the left to the curved edge on the right
How do you change that?
Message 8 of 19
fusiondesigner
If you see the first picture I posted above, I would switch the direction by putting 11.5 in "Start", and 0 in "End", basically swap the values.
Message 9 of 19
davebYYPCU
Highlights in the Dialogue Box show the active handle,
blue arrow, = blue dialogue line,
enter appropriate values in appropriate boxes.
Might help....
Message 10 of 19
jda70az
Didn't work for me...
If you look in my file you will see in the time line I used loft to make that Body.
Load up my file and select Body 18 and do a fillet like you did in your example.
I keep getting an error.
Error:
The fillet/chamfer could not be created at the requested size. This might be occurring at the ends of the selected edges. Try adjusting the size or using multiple separate operations. Check that the selected edge chain ends at a sensible position, and if not try selecting more edges.
Message 11 of 19
jda70az
Im working on it  🤔
Message 12 of 19
fusiondesigner
Several things:
1. The file you attached is probably an older version, there was no "Body18", but I think I figured it out.
2. I think you are thinking about the filet in the wrong direction. The rounded sketch profile (endneck) side already has a radius, so you do not need to apply a filet to that side. But still, because its a loft, Fusion 360 can behave weirdly.
3. The problem with the weird behavior gets solved if you create the loft as a separate body, instead of merging it with the rectangular neck behind it.
4. See attached. I edited the loft to be "New Body" instead of join (this created a Body18). Then played around with the filet on the lofted body until it looked right. Then set the filet/radius on the body behind it to match. Then you can combine the bodies back together.
Message 13 of 19
laughingcreek
one thing to keep in mind is that it's not general a god idea to use fillets like this.  it is intended as a finishing tool, not a modeling tool.
a few thoughts on your model-
-why is the profile of the very first sketch (top) moved off it's sketch plane into 3d space?  this is practice will probably give you grief down the road, and isn't a great idea.
-then there is this gem in the end neck sketch
that tangent constrain is pulling the end of that spline to be tangent with the vertical line.  there is a microscopic bend there that is wrecking havoc on any surfacing tools you might be trying with that profile.  here is the curvature map of a loft using that profile-
anyway, I said something about it not being a good idea to use fillet as a modeling tool.  Of course now I'm going to turn around and use it as a modeling tool.  I guess there are exceptions to every rule.  I'm not sure what your envisioning for that transition, but here is a possibility.  adding a fillet to the edge of the extruded block makes the transition to the curve of the neck go smoother.  still not great, I would prefer to add some rails to either side of the fillet and smooth out the fade, but it's a start.
Message 14 of 19
laughingcreek
here is what I mean by adding some rails to smooth the transition.
Message 15 of 19
jda70az
Why? Because I'm a noobie .
I checked out your file and that's pretty good.
Couple things tho...
There is a problem area where an edge didn't stay inline on the top of the Heel.
There are a bunch of purple lines in there and I don't really understand how you did that.
I get that you would use Loft and Rails but not how to get them in the right spots.
Also I am not able to move the curvature handles around to change the shape of the curves.
Here are some  images I took of a real guitar neck I have
so you can better see the shapes.
Message 16 of 19
laughingcreek
check. There are of course perfectly good reasons why you might have a sketch off in 3d space, so I wanted to ask. rule of thumb. have a reason, or keep it 2d.
oops, got lazy. when combining flat straight sections with curves in a single loft you have to be careful with your rails. (well, gotta be careful any way, but extra careful).  The attached has a few added, hopefully it's better.
the purple lines are projections. in this case fusion added them automatically when I added the rails. The rails are constrained to be tangent to the edges of the helper body I lofted in as a surface. (the body named "helper").  The procedure was
-to start a new sketch, select any plane (I selected the xz origin plane) for the sketch plane
-make sure 3d sketching was turned checked on
-draw a 2 point fit point spline between the vertexes
-apply a tangent coincident between the spline and each edge (this is the point where the purple line will appear. fusion does that automatically.  don't care for it, but oh well)
once a curve is off the sketch plane and out in 3d space, it can only be manipulated with the move command. messing with 3d splines is quirky, requires patience. select a tangent line endpoint, right click, select move from the marking menu. since there is a tangent constraint it will only move along a line, but you can shorten and lengthen it.
ahh yes, and the rest of the story.
so we need to step back and take a slightly different run at this if you want that well defined edge.  the current approach won't get there with out some modification.
Message 17 of 19
jda70az
I have attached a simple file I did with just Sketches if you want to take a look?
As for your question about  the real guitar neck heel ..well its edge has a slight bevel / chamfer to it.
Because it's been sanded with sand paper.
But I don't really need that per say in a CAD file. That would be something done by hand
after the machining process.  So I wouldn't bother trying to model that.
Only reason I tried to model it was because I was having so much trouble trying to match up
the lofted parts and using Fillet I added that as a band-aid. Which didn't work out.
Message 18 of 19
laughingcreek
have a look at the attached. might help with ideas on doing this
Message 19 of 19
jda70az
Nice.
I really appreciate that.
Helps a lot.
