Spline pins are really much like any other geometry when it comes to constraining them. It is just that due to the
nature of splines they tend to be at odd angles and differing lengths and that sort of thing. It is possible to lock
down a spline, it just normally takes a while and one of the biggest reasons why the forum recommends that with
splines - less is more. Keep the points to a minimum so that you can lock them down and you usually get a much
better result with fewer of them.
Constraining a spline is typically done by dimensioning a length first and then giving it an angle relative to
something else in the sketch. If you are lucky you might get away with that but often you also have to dimension
the points at the ends too. LOTS of work. Treat each individual spline point bar as any other line. You can put vertical
and horizontal constraints on them like other lines. You can also make them co-incident if you need to.
Good luck
Cheers
Andrew
