How to design these models
memo2022
Message 1 of 58
memo2022
Can anyone help me in video showing how to design what is in the attachement. If you play the video you would see how it designed but I do not know how to design it so please by video showing what to do to design it thanks
Replies (57)
Message 2 of 58
jhackney1972
You attached your model but a video, you refer to, is not attached.  Try to submit it again.
John Hackney, Retired
Message 3 of 58
Drewpan
There are plenty of videos on the AutoDesk Fusion site to learn the software. The Documentation files are also filled
with short tutorials. You need to learn the software before trying to model something complex.
That being said, the little row of icons at the bottom is the Timeline. If you slowly step through the timeline at one
icon at a time then it will show you how the model was created.
Each icon is a step in the process and they tell you what they are. While you can use this to work out how it was
done you would be better off doing it yourself. There are some dubious steps I can see in this timeline that are
not good workflow methods.
Cheers
Andrew
Message 4 of 58
etfrench
Just revolve this shape:
Then add the arms using another sketch. Extrude and Pattern the arm.
Notes:
Draw the center at the Origin.
Don't use the Move command to position bodies.  This will lose their position relative to the sketch(es) used to create them.
ETFrench
Message 5 of 58
memo2022
Here we go
Message 6 of 58
memo2022
Can u show it in video please
Message 7 of 58
etfrench
It's pretty straight forward once you've created the sketches.
@jeff_strater A rather embarrassing bug in the circular pattern.  Note that a quantity of 6 was entered, but only 5 exist.
ETFrench
Message 8 of 58
memo2022
Thanks for this video really helpful. There is a another step before that which is sketching before evolving how to do it please thanks again
Message 9 of 58
etfrench
Draw the revolve profile on the XZ or YZ plane with the center on the origin.  Draw the extrude profiles on the XY plane.
ETFrench
Message 10 of 58
TheCADWhisperer
@memo2022
Whoever did the original design did not know how to use Fusion - so we will start over from scratch step-step.
Step 1.
Start a new file and then start a new sketch on the XZ Plane.
Sketch a vertical line as shown below at the Origin.
Dimension the Vertical line a height of 3.5mm
Right click on the Vertical line and select Centerline.
Step 2.
Sketch a Horizontal line from the Origin to the right as shown below...
Note the white dot on the end of the Horizontal line.
Dimension from the centerline (pick the centerline) to the white dot (pick the white dot) as shown...
Note that the white dot now changed to black (fully defined).
Step 3.
Sketch a Vertical line and dimension 15mm as shown.
Attach your progress file here for next set of steps.
Message 11 of 58
memo2022
When I do right click it does not show normal centreline????
Message 12 of 58
laughingcreek
in that pic your dimensioning tool is still active.  select cancel, select the line, and right click again.
Message 13 of 58
TheCADWhisperer
@memo2022
Where did you go - we were just getting started on learning efficient, robust and predictable modeling techniques?
Message 14 of 58
memo2022
I am here sorry I just finished work and back home. It does not show when I press cancel.
Message 15 of 58
TheCADWhisperer
In your video I never saw you select the vertical line.
(Tip: Selecting a Point is different than selecting a Line.  A point is a point and a line is a line.)
Message 16 of 58
memo2022
I have done please see the attachment.
Message 17 of 58
TheCADWhisperer
@memo2022
Keen observation is absolutely critical in the field of design.
Your 56 dimension is a radius rather than diameter (Ø56) as shown in my instructions.
The diametral dimension is the reason we created the Centerline.
Post corrected file here for next set of steps.
Message 18 of 58
memo2022
I tried it did not work can you make video showing how to make it please
Message 19 of 58
TheCADWhisperer
Before I make a video - can someone else go through the steps I presented in Message 10 and review if I missed something important. I don’t want to create a video where I make the same mistake of omitted information.
Message 20 of 58
MRWakefield
I've checked and your instructions are very easy to follow and are correct apart from cancelling the dimension tool before right-clicking the first line (which you addressed in post #12).
p.s. I admire your patience!
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
