Message 1 of 1
Image Cleanup after using IMAGE to SURFACE add in
Hi: I imported an image into Fusion 360 that I want to carve with my CNC. The Image to Surface tool works well but some areas need to be raised up where I2S interpreted shadows incorrectly. I tried editing the form and pulling the T-splines and also tried moving the faces. I can select the faces but when i go to "move/copy" I loose the selection.
I am new to surface modeling and I haven't been able to figure out how to do this. I have attached the original image where you can see an example of the shadows, how it gets interpreted in Fusion 360 (and needs repair) and the Fusion file. thanks
