How to delete empty project folder
kshea9RNL8
Message 1 of 12
kshea9RNL8
Have spent some time searching but haven't found out how to delete a empty project folder from the Fusion 360 Data Panel?
Replies (11)
Message 2 of 12
PhilProcarioJr
@kshea9RNL8
As far as I know you can't delete project folders at this time, but what you can do is right click on them in the browser and archive them. That will remove them from your browser.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 12
kshea9RNL8
I guess that would account for not finding anything 🙂
Actually I did find instructions but they did not appear to apply to the current version, layout was different.
Message 4 of 12
PhilProcarioJr
@kshea9RNL8
"Actually I did find instructions but they did not appear to apply to the current version, layout was different."
You can only delete folders in the project folder unless something has changed.
This is one of the reasons I created a master project folder that is nothing but a container for all my other projects.
Then when you create a folder that will contain your project under that master folder they can be deleted if needed.
Not ideal but it works, I seem to remember that the dev team was going to address this issue at some point, they can correct me if I'm wrong.
Phil Procario Jr.
Message 5 of 12
HughesTooling
@PhilProcarioJr wrote:
@kshea9RNL8
Rather than archive an empty project why not just rename it and use it for your next project.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 12
kshea9RNL8
Now why didn't I think of that.
Message 7 of 12
kshea9RNL8
Another good idea!
Message 8 of 12
PhilProcarioJr
@kshea9RNL8
Another reason I use a master project folder is I can add a hardware folder with subfolders like screws, nuts, bolts etc. and all my projects in the master project folder can use those pieces of hardware. If I move a part or an assembly that uses those parts I don't get move errors IF I still have linked components. (Which I usually try not to ever have but sometimes it is needed)
This keeps data neat and organised in my data panel too.
MASTER PROJECT
  Hardware
    Screws
    Nuts
    Bolts
    Brackets
    Etc
  Rapid prototype machines
    Delta
    Etc
  CNC mills
    Engraver
    3 axis
    Etc
Phil Procario Jr.
Message 9 of 12
kshea9RNL8
I can see the benefit, going to put that into practice!
Message 10 of 12
The only Way I have found to delete a folder is to archive it. This gets rid of it.
Message 11 of 12
oh, I also forgot to add to then go to the archived section on your online A360 profile and you will see a delete button there.
Message 12 of 12
HughesTooling
@Anonymous Yes that is the correct way. The 2 stage process is probably a good thing as there have been quite a few people complaining when they've deleted a design and can't get it back, it does warn you files can not be recovered but still people still do it.
Mark
Mark Hughes
