how to cut a dome shape into spiral
rajsumanth9
Message 1 of 13
rajsumanth9
I have attached a file which has a dome shape , I want cut the white part and remove , so the dome shape is converted to spiral , can anyone help me with this , and share me their knowledge how to cut dome shapes to spirals
Replies (12)
Message 2 of 13
TheCADWhisperer
I made a mistake in Copy of original when I should have used a different pitch for the second spiral.
But the Attached might give you some ideas...
Message 3 of 13
WHolzwarth
Here's another idea. I've used an Equation curve Add-In, together with some zigzags in my workflow.
Walter Holzwarth
Message 4 of 13
rajsumanth9
sir , I get the message in the screenshot when I opended your file , I have downloaded and installed drive cure add in also
Message 5 of 13
WHolzwarth
Hard to tell from here. Perhaps it's caused, because you're opening it with an Education license.
Can anyone else test with an Education license?
Walter Holzwarth
Message 6 of 13
WHolzwarth
Meanwhile I've seen others with similar problems.
https://forums.autodesk.com/t5/fusion-360-design-validate/error-quot-try-again-after-update-complete...
Walter Holzwarth
Message 7 of 13
rajsumanth9
sir , firstly I want thank you so much....for giving your time...I have tried it multiple times but failed
Message 8 of 13
rajsumanth9
sir , is there any chance you can screen record
Message 9 of 13
WHolzwarth
Perhaps we can avoid a video. Can you show us your file at first?
Walter Holzwarth
Message 10 of 13
TheCADWhisperer
@rajsumanth9
What version of Fusion 360 are you running?
Mac or Windows?
Message 11 of 13
rajsumanth9
windows 10
Message 12 of 13
WHolzwarth
Hmm. I'm here with Release 2.0.12157 of Fusion360. Are Education licenses limited with updates?
Walter Holzwarth
Message 13 of 13
TheCADWhisperer
@rajsumanth9 wrote:
2.0.10806
windows 10
Find the Fusion 360 Client Downloader *.exe and double click to force an Update.
Search your hard drive for this file.
