- Mute
- Permalink
- Report
Hello, i've learned the basic of Fusion 360 and it looks a powerful software. Forum and tuto helped me a lot, thanks for sharing your knowledges here and there ! The path seems long for me to reach some skilled level i've seen here.
I've designed something "manually" but as i would have to repeat it, it may exist a more appropriate way to do it.
I started to drawn a rectangle volume. I draw a curved line (sketch) on X. Then an other curved line (sketch) on Y. Then i manage to "center" them with the volume, and use them to "cut" the volume.
Not sure it's that clear, so the image here represent sketch X and Y, and the volume cut. What feature would you use, or how you would proceed ?
The object will be attached to a helmet, so it needs to be "curved cut" in both direction.
If something similar has been done in the forum already, i apologies haven't seen it yet, just give me a link to it.
happy design to all !
