Analysing mechanism
Analysing mechanism
Analysing mechanism
I have a mechanism that converts rotary motion into linear motion and I would like to analyse this mechanism by exporting to a spreadsheet selected features/dimensions of this mechanism.
For example, for every degree of rotation at A, what is the distance between B and D - and export this data to spreadsheet.
Is it possible in Fusion?
sachlene.singh
Hi @Anonymous,
There isn't a way to do this in Fusion. While you can animate the mechanism to show the motion, there isn't a way to export it to a spread sheet for analysis. The workflow is usually one where you can specify the translation of motion when the joint is specified, so something like a specific gear ratio, can be entered when the mechanism is modeled so that it animated accurately.
The alternative way to animate the mechanism is to set up a contact set, but that again does not export data as a spreadsheet.
I hope that answers your question,
-Sachlene
Thank you, Sachlene.
It is a shame, because at the moment animation seems to be more about presentations than design and motion study doesn't really help much... but it is what it is and I love Fusion360 anyway!
Yes, it does answer my question - thank you
Chris
