how to create this groove?
TheCADWhisperer
File>Export and then Attach your *.f3d file progress thus far.
Attached file Assign 1-4 Top Bottle nr delete v1.f3d
chrisplyler
With a mold? What are you asking specifically?
TheCADWhisperer
Your first sketch is not fully defined.
Your second sketch is not fully defined...
I stopped there.
Define your sketches and post again for next step.
If this is a student project - you have picked a project that is too complicated and you have not received proper instruction from your instructor on creating sketches.
As encouragement - I did this with the same techniques that I would use for your design.
Could you detail out where to follow the tutorial on the suggested vacuum cleaner?
JDMather
How does a pretty picture solve anything?
Do you know what it means to fully define a sketch?
Let’s go back to your original problem.
