02:26 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Attached file Assign 1-4 Top Bottle nr delete v1.f3d
With a mold? What are you asking specifically?
Your first sketch is not fully defined.
Your second sketch is not fully defined...
I stopped there.
Define your sketches and post again for next step.
If this is a student project - you have picked a project that is too complicated and you have not received proper instruction from your instructor on creating sketches.
As encouragement - I did this with the same techniques that I would use for your design.
Could you detail out where to follow the tutorial on the suggested vacuum cleaner?
How does a pretty picture solve anything?
Do you know what it means to fully define a sketch?
Let’s go back to your original problem.
