How to create such a pole
Beginning from diameter 120mm at the bottom up to diameter 60mm at the top.
jeff_strater
I'd either use Loft or Revolve.
For Loft, you'd need two circles, one 120mm and the other on an offset plane at the top of 60mm, and create a loft between those two circles.
If you want to use Revolve, then you'd create a sketch which is a half cross-section of the pole, with a line that is 30mm at the top, and a 60mm line at the bottom, then revolve around the center axis.
If this isn't clear, I can provide a quick screencast.
Jeff
Jeff Strater
Engineering Director
Hi Jeff,
Thanks! You would help me with a screencast. 🙂
jeff_strater
Here is a screencast showing the two different methods:
Jeff
Jeff Strater
Jeff,
Thank you very much! Appreciate it.
