How to: Create Loft between 2 bodies
deonholt
deonholt
Hi everyone and thank you for your help.
How do I create a loft between these two bodies as below? I'm getting errors. But when these two bodies are not extruded without offsets, it works perfectly. I need to connect two bodies that are extruded with one another.
Thanks.
g-andresen
In solid mode, it is not possible to loft a hollow body.
Here you must first loft the solid body and remove the inner areas with a 2nd loft.
Screencast
günther
deonholt
Thank you very much.
I have just tried to replicate your video ... without success.
I designed the same as you ... or it looks the same. You have an extruded rectangle and a extruded circle. You click on the top face of the rectangle and the bottom face of the circle and loft them successfully.
Why can I not do the same? Maybe we used different steps to design the extruded bodies?
Here is my effort:
https://autode.sk/2Rxlyc9
jeff_strater
helping out @g-andresen , in case he is offline at the moment.  The missing piece of information here is that there are sketches placed on the bottom of the cylinder, and the top of the block.  This gives you a sketch profile to loft for the cut phase:
Jeff Strater
Engineering Director
g-andresen
@jeff_strater  is right.
I created the outer loft with the  rings (sketch profiles) and the inner cut with the inner profiles.
günther
deonholt
Thank you so very much, guys. The solid sketch for the rectangle and circle were the two thing I missed. It works perfect. Thank you once again for your patience and help. 👏
