Copy Component To New Project
MaxHugen
MaxHugen
Can a component in a project be copied to a new Project?
My current SailGP "F50" project is already ~80Mb in size, and I'd like to copy a component to a new Project, so I can experiment with better ways to design it - still learning F360 techniques.
Once I'm happy with it, I'd "link" it to the main F50 project.
jhackney1972
You sure can, it can be done from the Fusion 360 Data Panel.
John Hackney, Retired
MaxHugen
Sorry, I probably wasn't clear in my post... I have a Project with a number of Components in it, and I'd like to copy one of those components into a new Project?
MaxHugen
Found the way to do it... too easy!  Right-click the Component, and select "Save Copy As", which will create a new project.
jhackney1972
The name you gave to an assembly, containing your components, calling it a project confused me.  Projects are major divisions under your team account which contain your assemblies folders and individual components.
Ajay_Kumar_Reddy
Hey @MaxHugen,
adding to @jhackney1972, sometimes it won't allow you to copy to the projects that might be created by other people or it can be a team. If that is the case, just export it and upload it Export.pngupload.pngto the desired location and experiment the way you want.
MaxHugen
Yes, I realised later as a newbie that I had my terminology wrong!  I've now read up a bit on the Team and Project/File structures, so have a slightly better understanding of it now.
BTW, watched some of your videos, very interesting. 🙂
Cheers, Max
