Announcements
how to create impression on sculpt body (seat)
 Now that i have the dimensions and shape i want on my sculpt body, how do i modify it as a seat with leg and bottom impressions? Also, how do i change the t-spline configuration?
innovatenate
Autodesk Support
Autodesk Support
There's a couple of ways to achieve what you're after.
One method may be to use the Edit Face command available in the Direct Modeling environment (Use Create Base Feature command first). See the below video for more.
Nathan Chandler
Principal Specialist
innovatenate
Autodesk Support
Autodesk Support
Here's another way to do it using the Sculpt Evironment only.
http://autode.sk/1zDV32y
Nathan Chandler
