How to create component parts properly
ianhughes7UFVF
ianhughes7UFVF
Hi
I am in the process of building this frame with mech that will extend from the frame holes.
I am not sure how to correctly do it. I have attached the file.
What I did was sketch a circle on the side plate and then extruded the circle and then chamfered it. But it appears to have joined the upright side of the frame.
I want this to be a separate item so that I can get it 3d printed.
Was the way I was doing it correct and is there a way to separate the item into a separate piece or component.
I had thought that I should create a component item in the menu and then create this part.
Kind Regards
Ian
g-andresen
Hi Ian,
try it this way.
Finally, you create a component from it.
günther
ianhughes7UFVF
Hi
Thank you for showing me how to separate the part from the frame. Atleast I know that that is the process to make the part.
My next question you inferred any way. It treats it as a body when it is created. I would then need to make it a component. How would I do that. Is this where I would make a new component in the Menu, name it and then drag the body into it making it the component?
Kind Regards
Ian
g-andresen
mark the body >right click
günther
