- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I am in the process of building this frame with mech that will extend from the frame holes.
I am not sure how to correctly do it. I have attached the file.
What I did was sketch a circle on the side plate and then extruded the circle and then chamfered it. But it appears to have joined the upright side of the frame.
I want this to be a separate item so that I can get it 3d printed.
Was the way I was doing it correct and is there a way to separate the item into a separate piece or component.
I had thought that I should create a component item in the menu and then create this part.
Kind Regards
Ian
