How to create component hierarchy
richard.finlayson
richard.finlayson
I am new to Fusion360 had having a blast. I built a single body up from sketches, pretty fun. It's just one component of my final assembly though.  I just converted it to a component, but have two problems. I can't figure out how to create what I think of as the final assembly, which I think it also just the lop level component. And, when I right click to create a component, it looks like it is creating a component WITHIN my one component that I have. (Can a component actually include other components?)
To summarize, I need to create a top level component, above the one I just created from my body, and then create more components that are at the same hierarchical level to my one component.
laughingcreek
yes, you can have sub-components inside components.
new components will be created under the sub-component that is active (radial button)  if you use "create->new component".
they will be created under the component you right click on if you use "RMB->create new component"
Hi, how do i move a component inside another one, to make it a children of that component ?
g-andresen
drag&drop
günther
