Here's my problem: I created an assembly with some angle iron frames, using the same angles as a component a few places since it was the same length. As I got further into the design I wanted to add some holes to only one of those angle.
Problem is anything I do to the one component is done to the other, which messes up my drawings.
I attempted to copy and "paste new" on one of the components to create a new unique instance but that seemed to cause issues in my drawing, as did trying to delete one of the components (likely due to how I extruded the object and placed joints).
Is there any way to create a new component from an existing so I can only modify one of these angle irons with new holes? Anything I've tried seems to break the model, so far my best plan is to mark up the drawing in AutoCAD with the appropriate holes so I can send it out for fabrication.
