Having modeled a simple box as in the screenshot, what is the easiest way to cut a grid out of the bottom of it, on a diagonal? For example, cutting a pattern of 18mm squares spaced 20mm on center to leave behind that 2mm grid structure?
This is easy to do with a rectangular pattern of squares as long as it is aligned with the x and y axis. But the only way I have found to do this so far, is to rotate the box 45 degrees , cut the grid, and then rotate the box back.
Is there a less kludgy way?
