How to Create a Grid at 45 Degrees to Sketch Plane
jhawkinsRXEMB
jhawkinsRXEMB
Having modeled a simple box as in the screenshot, what is the easiest way to cut a grid out of the bottom of it, on a diagonal? For example, cutting a pattern of 18mm squares spaced 20mm on center to leave behind that 2mm grid structure?
This is easy to do with a rectangular pattern of squares as long as it is aligned with the x and y axis. But the only way I have found to do this so far, is to rotate the box 45 degrees , cut the grid, and then rotate the box back.
Is there a less kludgy way?
Drewpan
I would have to say after playing with it for a while, your kludgy way works so stick with it. I tried to do a similar
thing except with sketches but I ended up using a rectangular pattern and rotating it also as you do not seem to be
able to rotate a rectangular pattern. With some complex mathematical calculations it is theoretically possible to do
what you want with a circular pattern but why would you when a quick rotate and back works. This is one of the
very few occasions that you "might" use the Move command.
I could see a very useful function if I was able to rotate a rectangular pattern before placing it in the design space
for exactly the same sort of reason you are asking about. Maybe @jeff_strater might want to have a look at it as a
function update?
Cheers
Andrew
djlunty
@jhawkinsRXEMB
Assuming the box is square Construct>Axis Through Two Points - the points being opposite corners of the box and use this as the Axis for the Pattern Feature.  Might be a bit less kludgy.
If not square draw a point the distance of the short side to use as the second point for the the Construction Axis
doug
Drewpan
Good solution. I have just been playing with Planes on another forum question and creating an axis is just below
the plane tools. Doh!
I still think that the ability to rotate a rectangular pattern before placement would be a good tool to have available.
Cheers
Andrew
davebYYPCU
Maybe jeff_strater might want to have a look at it as a function update?
Done!
Rectangular pattern on angle, select angle of the hole side/s.  KISS
Pattern of cut holes will leave the grid
Might help.....
jhawkinsRXEMB
Exactly what I was after. It appears to work for drawings as well as objects/features. Thanks.
