Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
As you can see, this vector has a lot of different edges, which would make beveling this thing difficult because I would have to select every single edge piece and then bevel. How do I just combine the entire edge, so I can bevel all at once and work with it as a single piece, rather than lots of little piece?
Thanks in advance!!
As the edges do not connect tangentially you can't select all chained edges.
However: If you select the top face it will bevel all edged that are part of that face.
1. SELECT > selection filter > deselect "All" > select "Edges" & "Through
2. window selection > your geometry > create fillet
3.
Please share the file so we can see the character of the base geometry .
File > Export > save as f3d to local device > attach to next post.
günther
Is that going to be a company logo?
If so, I would take the time to recreate from scratch with high quality geometry.
I would want my logo to represent high quality - no shortcuts.
It seems like a logo design. In this case, making any changes to the edges of that model will be tough. You have to select the segment with the "ctrl" key.
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
You can also select the top face and let us know the result.
Thank you.
RUET
Thank you.
Thank you. I imported a vector, and when I attempt to extrude it, this is the issue I was getting, shown in my original post. I attached the file here. I really appreciate your help.
