How to collapse moves on the timeline?
karl
karl
I'm designing a remote head for my PC, so I've created models of the pieces that will go into it (power button, reset button, USB ports, etc.), and now I'm moving them around as I try to decide the final arrangement before designing the box that will contain them.  As you can see in the attached screenshot, these moves are kind of cluttering the timeline.  Is there a way to eliminate all the intermediate moves so I'm left with just the final configuration?
HughesTooling
Ideally each part would be a component and you'd position with a joint. If you want to stick with using bodies then use a translate, not a free move and then edit the move, don't keep creating new ones.
As you can see translate keeps a record of the position.
Mark Hughes
Owner, Hughes Tooling
karl
Thanks!
