Message 1 of 22
07:30 PM
I'm very new (1st sketch!) to Fusion 360.
I have createsd a pulley as a 2d drawing in Gearotic and I have imported the file as a DXF. When I do so, the pulley is sitting vertically so that if I want to extrude it or pull it, it wouls happen in the Y axis and not the Z axis. I would like to move the pulley to be flat so that if I extrude or pull, the object gets larger in the Z direction.
I tried to select all and do a copy. Then I deleted the gear and tried to paste it into the appropriate plane and it didnt work, there was nothing in the clipboard.
Can someone lend a hand? Thanks, Tom
