How to change the model reference for a drawing
I've tried searching but haven't found an answer; Is there a way to change to model reference for a drawing? I have a model that I started working on the drawing for but then had to make changes and save the model under a new name which the existing drawing will not reference. In other packages it is possible to change the drawings reference and thus avoid having to redraw numerous views and details for a similar part. Is this possible in Fusion?
TMC.Engineering
Currently there is no way to do this.Smiley Sad
This is a link to the ideas request
http://forums.autodesk.com/t5/ideastation-request-a-feature-or/2d-drawing-change-reference-link-of-o...
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
How frustrating!
Thanks for the quick response though 🙂
Hi, Do you know if this is still the case or if it's been patched in?
Has this been patched yet?  Or is there a workaround?  I have several assemblies that are very similar, and need drawing packages for all, would hate to have to repeat work.
barry9UDQ6
You can set up a template with placeholder drawing views.
