How to chamfer a conic curve?
7 REPLIES 7
Message 1 of 8
Magic_Turtle
358 Views, 7 Replies
Was wondering if there's a simple way to get a chamfer on such a tight curve that goes the entire height of the part.
7 REPLIES 7
Message 2 of 8
etfrench
in reply to: Magic_Turtle
Loft will probably be the best way.
ETFrench
Message 3 of 8
davebYYPCU
Yes, 0.0295 inches max
Might help....
Message 4 of 8
Magic_Turtle
in reply to: etfrench
How would I use loft to make a chamfer?
Message 5 of 8
davebYYPCU
The reason the Chamfer fails at or above 0.0295in (very small) is that a bigger chamfer will cause the curve at the nose to convert to a point.
The size of your chamfer required is not mentioned, the block is 0.5 thick.
Somethings are difficult or impossible.
Might help...
Message 6 of 8
Magic_Turtle
in reply to: davebYYPCU
Very helpful thank you!
Message 7 of 8
etfrench
  1. Create a sketch at the lower level of the model.
  2. Project (or Project Intersect, depending on the shape) the body to the sketch.
  3. Create a sketch at the top level of the model.
  4. Project the top face to the sketch.
  5. Convert the projected geometry to construction lines.
  6. Offset them to the desired width of the chamfer.
  7. Adjust the profile by adding fillets at sharp corners.
  8. Loft between the profiles on the two sketches.
  9. Split Body using the loft as the cutting tool.
Note: This workflow works fairly well for text.
ETFrench
Message 8 of 8
Magic_Turtle
Worked amazingly! Thank you!
