Was wondering if there's a simple way to get a chamfer on such a tight curve that goes the entire height of the part.
Solved by etfrench. Go to Solution.
Solved by davebYYPCU. Go to Solution.
The reason the Chamfer fails at or above 0.0295in (very small) is that a bigger chamfer will cause the curve at the nose to convert to a point.
The size of your chamfer required is not mentioned, the block is 0.5 thick.
Somethings are difficult or impossible.
Might help...
Note: This workflow works fairly well for text.
ETFrench
