How to angle velocity stacks?
e2101391
Message 1 of 12
e2101391
How can I angle/tilt a velocity stack/intake trumpet? I can make a straight or tapered one by using the Revolve tool and keep the end details. Let's say I want 20 degrees from the base plane and a gradual angle to it. Is it possible to use the profile where I have the shape of the trumpet to just make it follow a line instead of an axis?
Edit: File below I managed to create the pipe section using loft. I want to create the circle shape to the edge and have it easily change length for different versions. Also to be able to change taper angle currently 0.
Replies (11)
Message 2 of 12
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post.
günther
Message 3 of 12
davebYYPCU
Draw the centre line (any angle) but longer at the bottom face,
use Plane on Path, set to top of centre line, and draw circle.
Extrude.
Cut the bottom face with the base plane.
Warning :  Base shape will be Ellipse which can be drawn on base plate and Sweep along the centre line, cutting the top to be a circle.
Might help….
Message 4 of 12
e2101391
uploaded
Message 5 of 12
Warmingup1953
Message 6 of 12
e2101391
I want a gradual curve over the whole distance so no sharp turn at the base. thks anyway for the suggestion
Message 7 of 12
Warmingup1953
Message 8 of 12
TheCADWhisperer
@e2101391
Why did you Move your Extrusion rather than simply flip the direction?
Are there any unresolved issues highlighted in yellow on your Timeline?
Message 9 of 12
Warmingup1953
...Or if you need tapered:Screenshot 2025-03-16 073021.png
Message 10 of 12
e2101391
Thank you
Message 11 of 12
TheCADWhisperer
@e2101391
Can you upload your completed geometry - I suspect there is a cleaner more robust technique.
Message 12 of 12
e2101391
This is my first complete version for a test print. There are some things that most likely are not clean at all, and kind of a mess tbh.
