How to adjust the width of my 2D sketch?
Message 1 of 10
I used the scale function to scale the sketch up, from a few millimeters to a few hundred millimeters. However, the parameters (width) of my sketch is off by about +50mm, while the height is perfect (which makes sense, given that I scaled the sketch by the height). How can I narrow the entire sketch, so that the height stays the same, but the width changes? I tried to scale the sketch, but it wouldn't allow me to do non-uniform scaling, which I think might be the solution. I've attached a visual for reference.
Replies (9)
Message 2 of 10
laughingcreek
Can you articulate why scaling the sketch is the way to approach this?
Generally speaking, scaling is not a good approach to use for adjusting sketches in parametric modelers.  Fusion isn't CorelDraw or inkscape, and requires a different mind set and approach.  scaling may seem like the easy way to go, but making additional (and probably necessary) changes to your sketch will be a bear.
Message 3 of 10
I don't need to scale it, necessarily. Really, I just want to adjust the width of the sketch, without affecting the height of the sketch.
Message 4 of 10
laughingcreek
can you attach it here? (export as .f3d, attach to post)
Message 5 of 10
LeonardoBN
This is not so elegant, but you could:
1. Extrude your sketch;
2. Modify/Scale the solid in the non uniform way you want;
3. Create a new sketch and Project the shape.
Leonardo Brunelli do Nascimento
Chemical Engineer
Message 6 of 10
I am having trouble with Fusion360. It won't let me extrude the sketch. Do you have troubleshooting advice?
Message 7 of 10
TheCADWhisperer
Step 1. File>Export the file to local drive.
Step 2. Reply to this thread and Attach your *.f3d file here.
Step 3. Wait 5 minutes and @laughingcreek will answer all of your questions.
Message 8 of 10
Message 9 of 10
laughingcreek
What is it your hoping to make with this?  do you have a pic or a sketch?
these are very strange sketch entities, are they imported from another program?
imported curves are frequently a source of problems.   these are of terrible quality and are going to be extremely difficult to work with.
You can't extrude this sketch b/c it's not a closed profile (endpoints aren't all connected).   you also have a spline across the bottom that is twisted and folded onto itself.  that's going to be a problem when you start making solids/surfaces.
Good sketching skills are the foundation of modeling successfully in fusion.  I would suggest going through some of the tutorials on sketching, and then attempting to make this shape from scratch in fusion.  You'll end up with better geometry.  Make a go of it and attach your attempt here and someone will help.
Also, the way your approaching using the form mode isn't going to work out for you.  There's a lot more to it.  but that's a whole nother thing. let's start with the sketch. (actually lets start with a pic/drawing/explanation of what your trying to do)
Message 10 of 10
TheCADWhisperer
You have 12 sketches, you should have only 1 sketch. (And they are mostly tiny straight lines - rubbish.)
Come back and answer @laughingcreek questions and end all doubt.
