How to adjust location of data entry pop ups
jeffescott
Advisor Advisor
jeffescott
Usually when I click on  a dimension to change, a pop up appears close to the dimension I clicked on.
Recently fusion is sending the pop up to random locations, often on my secondary screen, or even not on a screen.
This is of course frustrating, especially if it is off both screens.
How do I correct this behavior.
I think it is also sending the export file screen somewhere else as well since it no longer appears on the main screen.
Marco.Takx
Hi @jeffescott,
Is it possible that you often add extra monitors on your laptop that one time it is placed on the left and other time on the right?
This can be a Windows thing.
It is there for years for example using Inventor.
See a solution I posted years ago.
dialog-boxes-are-off-my-screen
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
jeffescott
Thank you that will help I thought it might be a windows problem.
Why do they get moved in the first place?
Marco.Takx
I think it has something to do with remembering the latest location.
Marco Takx
