Component Question
Component Question
jeffescott
Advisor Advisor
Component Question
jeffescott
I created several components and stacked them up in an assembly.
I needed to create a hole that goes all the way through all of the components.
So I created a sketch on the top one and extruded a circle through all of them.
My question does the newly created hole go with the components.  Or simple stay in the timeline?
Or more directly will it show up when I go to manufacture space with each component
jhackney1972
The hole will become a part of each component as long as you create the hole as an Assembly Top Level feature.  If you use an extrusion for the hole, you need to verify that the extrusion cuts all components, which is default unless you change it.
John Hackney, Retired
