HOW TO ADD CLEARANCE IN DESIGN
raihanrobin1602063
raihanrobin1602063
How you add clearance in your model for manyfacturing.
etfrench
The best way is to do it in the Manufacture workspace.  On the Passes tab set Stock to Leave either positive or negative.
Otherwise, you can set dimensions in sketches, use Press/Pull, use Extrude, etc..
ETFrench
raihanrobin1602063
Can u brief the passes tab?now i use extrude cut to make clearance
TheCADWhisperer
Attach example file here for illustration.
TrippyLighting
That question cannot be answered generally as that very much depends on the method of manufacturing.
For 3D printing, for example one has to modify the geometry of the model, either by changing dimensions or offsetting faces or other modeling methods.
If parts are sent out to supplier for machining, even if a 3D model is sent, it is usually accompanied with a manufacturing drawing specifying manufacturing tolerances. The 3D model would remain unchanged and is usually modeled to nominal dimensions.
