How to add 3D sketch to existing 2D sketch
broncomech
broncomech
I was asked to do some modifications to an existing project, most were simple edit the existing dimensions or add a fillet but one modification is proving to be very difficult.
There are a group of features that are perpendicular to a plane that the part owner wants rotated/tilted 15 deg.
3D sketch sounds like it should work but Fusion refuses to allow selecting the required plane when attempting to edit the existing sketch.
 I have managed to create the desired feature in a new project but can not duplicate the steps in the existing project, (see attached file). Is there any way to add 3D sketch elements to an existing 2D sketch?
TheCADWhisperer
@broncomech
There are multiple issues with this design right from the start.
But if you Edit a sketch, you can turn on 3D Sketching.
Check back in a few minutes.
Edit: I got pulled away into other stuff, but your first sketch is not fully defined. I doubt 3D Sketching will get you where you want to go with this.
broncomech
I edited the original sketch, turned on 3D sketch and could only sketch on the original plane.
Note the file posted was only a test not the file I am actually working on, that file is not mine to post.
TheCADWhisperer
@broncomech
You should get a 3D triad to manipulate sketch plane.
