How should I split this model into sections for printing?
matthewpolack
matthewpolack
Hi, This model is the lid of a fish tank.
https://a360.co/3HgGBWP
At present mosquitoes are landing in the water and breeding inside the house!
The idea is I will glue in some fly wire and this will be a cap.
It is too big to print on my Prusa Mk3s. I have designed it that it can be printed in four sections...with some joining tabs. My problem is I'm struggling to create 4 separate sections that I can save separately ready to pass over to Prusa slicer. Each time I push pull up it ends up joining bodies back together again.
I'm not sure if this is the best method..and also a bit unsure how I can split it into the 4 separate bodies I need?
Should I create components?
A work around is to pull up one section...then save...then flatten...then do the next section. I assume there is probably a way to just create all the 4 sections and save them individually. Thanks for any clues on how you would approach this. (I'm still learning basics!) Thanks.
g-andresen
Have you tried the splitting and joining tools in Prusa Sclicer?
günther
wersy
You do not need to save anything individually.
Simply split into 4 parts and save each part as an STL.
matthewpolack
Thanks. It's the 'split into 4 parts' where my problem is. I select the parts of sketch I want and push pull. This creates a body. But then when I select a new sketch and create a new body.. it ends up merging with the other body... Particularly as I have to select the outer rectangle and extrude it bigger again. I
Do I choose 'join:, ,New body' or 'component'. Logically I think 'new body' but for some reason I end up getting it merging with earlier bodies. I'm being tricked by something basic.. but I don't know what it is! Thanks.
wersy
Don't pull anything.
Just split the body.
The best will be to upload your file.
matthewpolack
Hi All. I found out the solution to my problem on a reddit post and what was causing it. When I extruded a secondary outer rim..it was joining to the first body..not the second..solution was here:
Problem:
Nope. Fusion will try to guess what body you want to join to based on where the sketch starts/what it hits, but there is no hard selection option.
Solution:
. If you hide the bodies you don’t want to join while you have the extrude menu open it will only join the visible body/bodies that are visible, and the ones you hid while the menu was open will reappear once you close ok or cancel
https://www.reddit.com/r/Fusion360/comments/xdoolr/join_sketch_extrude_to_specific_bodies/
Thanks all..I needed to hide bodies..then join..then use the "Save as Mesh feature" as shown above. Thank you!
