Dimension Change
Dimension Change
lara.michie31
Dimension Change
lara.michie31
Good day,
Please can I have assistance.
I am still new and learning how to use Fusion 360.
I have drawn my part and realized I put a dimension in incorrectly.
How do I got and change it without it messing up my entire workflow?
I would like to change the 103, which is the tip of the nose to 98mm.
If my workflow is incorrect, please can u suggest some tutorials to watch.
jhackney1972
You will have to clarify your request a bit more.  The largest diameter or radius in the area you indicated is 81 and 40.5mm respective.  You also need to add a lot more sketch constrains.
John Hackney, Retired
g-andresen
avoid fillets in sketches
günther
lara.michie31
Hi John,
Sorry yes, badly explained.
The overall length is currently 103.01, I'd like that length to be 98mm.
lara.michie31
Thank you so much 🙂
You made that look so easy.
